Create Time Function
Define amplitude versus time response curves for transient dynamics analysis or thermal transient analysis.
- In the Project Tree, click the desired dynamics transient thermal transient analysis.
                On the Analysis Workbench toolbar, click the
 icon.
                The Time function dialog will open. -
                Use one of the following processes to create the function:
Action Process Import from external CSV - In the dialog, select the Import CSV button.
 - Browse to the desired file and click Open.Note:
The file contents must have a header row followed by two or more rows of data. Each row has two values. Values must be separated with commas. The first is time and the second is amplitude.
Example: the file time-value.csv contains:time,amplitude 0.0,0.0 0.1,1.0 0.2,0.0
Create from standard template functions - In the dialog, select the Standard button.
 - In the Function type drop-down menu, choose the desired template.
 - For the Triangle, Rectangle, and Half-sine templates (pulses),
                                    specify Amplitude, Start, and duration. Tip: You may optionally define Period to make the pulse repeat for the entire time history.
 - For the Harmonics template, define Amplitude, Frequency F, and Phase of the harmonic function.
 - Click OK.
Create manually - In the dialog, select the Add row button. A new row will appear in the dialog's table.
 - Click in the row under Point #, Time, orAmplitude factor to activate a text box.
 - Enter the desired values.
Note:You can set a periodic time function by checking the option Set periodic in Create time function dialog. This will make the function repeat for the entire time history. To set a periodic function, the amplitudes at the first and the last points must be equal. The period of the function is always evaluated from 0.0 secs, except for standard time functions where the period can be defined in the dialog.
If this option is not checked and the time span is outside the range specified in the table, the corresponding amplitude is assumed to be equal to zero.
 - Click OK.
