Thermal analysis predicts how thermal effects propagate through the model. Steady
state and thermal transient analyses are supported.
Note: Thermal analysis is
supported for all connection types supported by
SimSolid. The table below summarizes the connections that
work as conductors and insulators. Regular connections, by default behave as
conductors but they can be changed to insulators at a global level or at
analysis level.
| Conductors |
Insulators |
| General Connector |
Remote Support |
| Pins |
Remote Mass |
| Rivets |
Liquid Body |
| Ball Joint |
Gas Body |
| Universal Joint |
Flexible Shaft Joint |
| Cylinder Joint |
Grounded Cable |
| Hinge Joint |
Grounded Rod |
| Linear Guide Joint |
Grounded Bushing |
| Cable |
| Rod |
| Bushing |
| Spot welds |
| Laser welds |
