SS-T: 4050 Coupled Structural Thermal Analysis
Create coupled structural thermal analysis in SimSolid for a piston head.
- Purpose
- SimSolid performs meshless structural
analysis that works on full featured parts and assemblies, is tolerant of
geometric imperfections, and runs in seconds to minutes. In this tutorial,
you will do the following:
- Learn to create coupled structural thermal analysis.
- Model Description
- The following model file is needed for this tutorial:
- ThermalStructual.ssp
Open Project
- Start a new SimSolid session.
On the main window toolbar, click Open Project
- In the Open project file dialog, choose ThermalStructural.ssp
- Click OK.
Create Thermal Analysis
Apply Convection
Create Structural Linear Analysis
Create Immovable Support
Link Thermal to Structural
In the Analysis Workbench, click
(Thermal load).
- In the dialog, select the Link to thermal analysis results radio button.
- Click OK.
Edit Solution Settings
- Double-click on Solution settings: for Thermal 1.
- In the Solution settings dialog, for Adaptation select Global+Local in the drop-down menu.
- Click OK.
- Right mouse click on solution settings and select Apply to all analyses in the current design study to apply the global+local adaptation to all other analyses in the study.
Run Design Study
Solve all analyses in the design study.
- In the Project Tree, select the Design study 1 branch.
- Click Run All Analyses
- In the Solver Manager, verify all analyses are selected.
- Click Solve.
