Find the distance between two points on the model.
                In the main window toolbar, click the
                    (Measurements) icon.
                In the dialog, click the Distance tab.
                In the modeling window, pick two points on the model
                    surface.
The dialog will display the distance between the two points.
Note: The
                        points do not have to lie on the same face; the distance is measured
                        directly through 3D space, not along the model surface.
                Click Close.
