Launch a ray through the model and measure lengths of segments where the ray
        intersects the model surface.
                In the main window toolbar, click the
                    (Measurements) icon.
                In the dialog, click the Ray probe tab.
- Optional:
                Orient the model so the desired ray direction is normal to the screen.
                Specify the Ray direction.
                In the modeling window, pick a point on the
                    model.
The dialog box displays the list of segments where the ray intersects
                    the model surface, as well as their lengths.
- Optional:
                Select two segments from the list to show the distance between the
                    segments.
                Click Close.
