Altair® Panopticon™
Using the Open Workbook in Design Mode
Property
Back
Exit the Workbook in Design Mode to go back to the Workbooks page
2
Data Table
Selected data table
3
Search Columns
Allows you to search for columns in the selected data table
4
Data Table Columns
Columns to drag to dashboard visualizations and parts
5
Workbook Data Table Editor
Displays Data Table Editor layout where you can further configure the data table.
6
Home
Allows you to go back to the Welcome page.
7
Edit Data Table
Opens the Edit Data Table Wizard. Enabled when the data table was added using the Add Data Table Wizard.
8
Add Data Table
Opens the Add Data Table Wizard
9
Dashboard
Selected dashboard where you can add, edit, and delete visualizations, filters, actions, and general parts
You can also create, edit, duplicate, rearrange, and delete dashboards.
10
Columns
Columns dragged to the X variable of the visualization
11
Breakdown, Columns, and Rows
Allows you to define hierarchical structures for the visualization
12
Visualization Variables and Filters
Variables and filters that can be defined for the visualization
13
New Dashboard
Allows you to add a new dashboard. You can also opt to select a template to use.
14
Workbook Theme
Select the workbook theme
15
Toolbar
Toolbar options in the Workbook in Design Mode
16
View
Go to Workbook in View Mode
17
Show Details
Displays information available in the Details variable of a visualization
18
Filters
Filters added on the dashboard
19
Visualization Context Menu
See Context Menu for more information.
In this mode, you can also perform the following operations:
q  Add dashboard parameters
q  Perform synchronization
q  Morph visualizations
q  Create actions and global filters for the workbook
q  View and clear active filters
q  Define the workbook theme
q  Interact with the visualizations
