udfGetElmCnn()
Return the element connectivity.
elemCnn = udfGetElmCnn( udfHd ) ;
User Defined Element
- udfHd
- The opaque handle (pointer) which was passed to the user function.
Return Value
- elemCnn (Integer*)
- Pointer to two dimensional integer array of element connectivity. The first (fastest) dimension of the array is the number of elements in the element set, nItems, and the second (slower) dimension is the number of element nodes, nElemNodes.
Integer* elemCnn ;
Integer elemNode, elem, node, nElemNodes ;
nElemNodes = udfGetElmNElemNodes( udfHd ) ;
for ( elem = 0 ; elem < nItems ; elem++ ) {
for ( elemNode = 0 ; elemNode < nElemNodes ; elemNode++ ) {
node = elemCnn[elemNode*nItems+elem] ;
- This routine expects a valid udfHd.
- This routine may only be called within a Body Force, Material Model or Component Model user function.
