udfGetElmName()
Return the user-given name of the element set.
name = udfGetElmName( udfHd ) ;
User Defined Element
- udfHd
- The opaque handle (pointer) which was passed to the user function.
Return Value
- name (string)
- User-given name of the element set.
String user_name ;
user_name = udfGetElmName( udfHd ) ;
udfPrintMess( "Inside element set with name <%s>", user_name ) ;
- This routine expects a valid udfHd.
- This routine may only be called within a Body Force, Material Model or Component Model user function.
