udfGetElmIds()
Return the user element numbers.
elemIds = udfGetElmIds( udfHd ) ;
User Defined Element
- udfHd
- The opaque handle (pointer) which was passed to the user function.
Return Value
- elemIds (Integer*)
- Pointer to one-dimensional integer array of user element numbers. This array has a dimension of number of elements, nItems.
Integer* elemIds ;
Integer usrElem, elem ;
for ( elem = 0 ; elem < nItems ; elem++ ) {
usrElem = elemIds[elem] ;
}Errors
- This routine expects a valid udfHd.
- This routine may only be called within a Body Force, Material Model or Component Model user function.
