Meshing
BatchMesher supports creation of feature entities and saves to the output .hm file. These can then be visualized and edited through the Feature Manager.
New Features
- Normals Context
 - New context workflow is available to reverse and adjust the normals of surfaces and shell elements.
 - Split Context
 - New context workflow is added to migrate the following panels:
- Element Split is now Plate Split
 - Solid Split
 - Layer Split
 - Combine
Enhancements
- Rebuild
 - Performance improvements.
 - Midmesh
 - Automatic extraction performance improvements for extruded parts.
 - Mesh Edit Workflow
 - This workflow is now migrated to Imprint context under the 2D ribbon.
 - Hex Tool
 - Added support for mixed guides selections.
 - FE Geometry
 - A new Coupled Show/Hide/Isolate mode has been added to bring the
                            Associated Element/Surface to the selected entity.
- This allows for the "classic" FE Geometry mode.
 - Extends to both CAD Geometry and FE Geometry.
