Post
New Features
- Free Body Section Context Menu
 - A context menu is now available to create and edit free body section entities.
 - Free Body Section Plot Context Menu
 - Context menu to create, edit, and display FBD plots is implemented.
- Similar behavior to the contour/vector/tensor plots. It reacts to the active loadcase.
 - Multiple plots can be created in the database.
Enhancements
- Memory Management
 - Improved memory management on result query.
 - Relative File Paths to Result Files
 - This tool now works with relative file paths to result files.
- Free Body Tools Migration
 - Force/Displacement and Cross section tools are removed.
- Use Create and Edit to generate free body sections.
 - Use Plot control to generate force & displacement plots.
 - Use the Manager to create
                                    loads/fields/summary tables from free body sections.
Figure 10.
Figure 11.
 - Browser Performance
 - Improved browser performance when loading a large number of result files is implemented.
 - Tooltips
 - A large tooltip with a complete definition of each free body section is
                                available.
Figure 12. - Custom Category-based Legends
 - A new type of category-based legend is supported. You can convert any
                            numeric result into categories and visualize it as a discrete,
                            range-based contour plot. For example, you can visualize a stress
                            contour plot as four categories by defining a custom category legend and
                            assigning it to the plot control.
Figure 13.
Resolved Issues
- Force/ Displacement /Cross section tools
- Several UI issue reported with these tools are fixed with new context menus.
 - Improvement on interface node detection by plane (compared to legacy cross section).
 - The "Copy legend" option, renamed to "Duplicate" in this release, now works as expected.
 - Changing the marker color no longer affects the contour plot legend.
 - The Legend position no longer changes when a deformed plot is applied (Linux only).
 - The "Reset legend" option now resets all settings.
 - Result plotting no longer fails when an input file is imported with "Create FE Geometry" ON in Solver Import Options.
 - The application no longer crashes on contour plotting stress results from Nastran .hdf5 result file.
 - CFAST element force vector is now displayed in the correct direction.
 - Issue plotting element forces on CBUSH elements no longer occurs.
 - Batch mode query no longer writes out an empty .csv when there are multiple result files.
 - hm_getdatatypelayers API now points to HyperMesh subcase IDs rather than results IDs.
 - hm_getsubcasedatatypes API no longer crashes when pointing to derived load case.
