Export and Data Check
Verify the model using Data Check
Before exporting the model, the setup can verified and checked for errors using the Data Check tool. This is accessed from the Solution Browser. Right-click the Solution Name and select Data Check. SimLab will submit the input files to nFX[p] and show the output log in the Output Window. This will report the status of the model and highlight any issues found in the setup.
For more information on nFX[p], see nanoFluidX Prep.
