Standard SPH interpolation heavily depends on the basic premise that each particle has the so called full support.
Full support implies that the owner particles can see particles all around itself within the smoothing length of the
particle, which mathematically implies that the sum of the kernel, also known as Shepard coefficient, is equal
to one.
Free Surface Formulation
Standard SPH interpolation heavily depends on the basic premise that each particle has the so called full support. Full support implies that the owner particles can see particles all around itself within the smoothing length of the particle, which mathematically implies that the sum of the kernel, also known as Shepard coefficient, is equal to one.
Keychain Validator
Keychain validator compares the keychains in the .cfg file with valid nanoFluidX keychains, when activated.
Operation Modes
The operationMode option allows you to change the solver for either minimal run time or maximum accuracy.
