In the nanoFluidX installation folder you will find the
PV_nFX_aux folder containing three additional folders:
PV_backgrounds, PV_materials, and
PVnFXTools. The ParaViewnanoFluidX toolbar is in PVnFXTools
folder.
The requirement of ParaView for automatically loaded
Plugins is to keep the location of the plugin consistent. For
PVnFXTools, this means the location of the folder and the
files in it should not be altered.
Copy the PVnFXTools folder to a location of your
choosing.
Important: For automatic loading of the Plugin, the folder and file
locations should not change.
Note: In some scenarios, ParaView explicitly
requests the PVnFXTools folder to be put in the
bin/ folder of the ParaView installation. For example:
C:\Program Files\ParaView 5.8.0\bin\PVnFXTools. If
you are using a ParaView installation on the
compute node, it is also possible to not change anything and use the files
in the original nanoFluidX installation
folder.
Open ParaView.
From the menu bar, click Tools > Manage Plugins.
In the Plugin Manager dialog, select Load
New.
Navigate to the PVnFXTools folder and select the
PVnFXTools_withtoolbar.xml.
In the Plugin Manager dialog, select the
PVnFXTools_withtoolbar plugin.
Enable the Auto Load checkbox and click
Close.
Two nanoFluidX menus appear in
the toolbar section of the ParaView user interface. The
tools should also be available in the Filters drop-down menu. The
coloring of the tools will appear only once the data is loaded into the session.
Essential nanoFluidX tools:
Threshold
Slice
Clip
Streamlines
Tube
Glyph
Contour
Calculator
Transform
SPH Line Interpolator
SPH Surface Interpolator
SPH Volume Interpolator
Extra nanoFluidX tools:
Plot Data
Iso-volume
Surface Vectors
Extract Time Steps
Temporal Statistics
Plot Selection Over Time
Compute Derivatives
Integrate Variables
Descriptive Statistics
Probe Location
SPH Dataset Interpolator
Resample with Dataset
Table to Points
Extract Selection
Programmable Filter
The majority of post-processing can be done with essential set of
nanoFluidX tools. The extra tools are intended only
for corner case post-processing requirements.
