Component Naming Conventions
- Body – Organize surface mesh of non-slip wall regions included in the force calculations in separate components and append “Body” to their names (for example, Body_Hood, Body_Windshields, Body_Mirrors).
 - Wheels – Organize surface mesh of rotating regions in separate components and append “Wheels” in front of the component names (for example, Wheels_Tyres, Wheels_Rims).
 - Moving Reference Frame (MRF) – Organize surface mesh of regions that will be defined as rotational zones to separate components (for example, MRF_Fan).
 - Baffles - Organize surface mesh of regions which are open and fluid on both side of those regions into separate components and append “Baffle” to components names (for example,“Baffle_wheel wells”).
 - Porous Media – Organize inlets, outlets and walls of Porous region and name them as HX-Inlet, HX-Outlet.
You are now ready to export the surface mesh to VWT. Exporting a NASTRAN / stl file is all that is required.
