Powertrain Modeling
Overview
- Import CAD
 - Create component sets
 - Defeature CAD as necessary (Optional)
 - Facet powertrain assembly
 - Patch openings and review
 - HX Modeling
 - Wrap with wrap controls (Assembly by assembly or entire underhood)
 - Wrapping quality: Check for bridging and that features are captured
 - Decimate (may not want to decimate too much)
Process
- Import associated CAD for the powertrain:
Figure 1. - Create sets based on analysis:
- Tools pull down > Create sets of components
 - Model browser > Show/Hide components by sets for further steps
 - Use sets to select component -> by sets
 - Defeature Geometry (Optional):
- Simplify model to avoid modeling unnecessary features like logos, solid holes, fillets, and so on
 - Find small parts and delete them
- Use find_smallParts.tcl script
 - Define 10 as threshold to find small parts (Generally nuts and bolts)
 - It will create a set will small parts based on tolerance
 - Right-click Isolate only to review the parts
 - F2 to open delete panel  Select parts to delete
 - Remove logo (Geometry --> Auto cleanup)
Figure 3.- Select logo and surrounding surface
- Selection does not need to be precise
 - It should cover all logo surfaces and surrounding surfaces
 - You can select all surfaces as well
 - Measure logo height beforehand to define in this utility
- Simplify parts
 - Solid hole removal
Figure 4.- Use solid hole removal in Geometry ribbon
 - In edit parameters, turn on the option to remove solid hole
 - Define maximum radius as 20 (Choose radius according to selection)
 - Create primitive shapes to model complex parts with cylinder, sphere or block
 - Tessellate CAD:
- Once done with geometry editing tool, tessellate the CAD to further
                                work on mesh-based tools like wrapper, hole gap patch, and so on
Figure 5. - Use rigid body mesher to tessellate
 - Define following parameters (for model in mm scale)
Figure 6. - Tips:
- Change maximum and minimum sizes according to scale of the model and level of details required.
 - Review tessellated mesh
 - Review that tessellation captures original shape as required
 - Review free edges:
- Tools > Edges > Free edges
 - Delete geometry to make model lighter (Surfaces and Solids)
 - Patch:
- Patch complex areas, gaps, solid opening
Figure 7. - Patch openings, solid holes (): Here you need to close opening of pipes, solid
                                holes so the wrapper does not go inside parts; if this happens, you
                                get exterior surfaces as wrap results
- Switch to Fill mode to “Hole fill”
Figure 8. - Select all components
 - Turn on Consider features which will consider solid holes as well.
 - Define hole width: 100
- Measure the hole length you want to close and define it as maximum width
 - For powertrain and underhood cases start with maximum width as 50
 - Review patches. Delete patch elements if not required
 - Manual patch as required by selecting Faces or edges instead of components
 - Close gaps in the model
Figure 9.- Switch to Fill mode to “Gap fill”
Figure 10. - Select opposite faces one in each group
 - Turn on Consider features.
 - Measure the gap length you want to close and define it as maximum width
 - Cover slots so that they are not exposed to wrapper; they are not
                                useful for analysis
Figure 11.- Switch to Fill mode to “Patch fill”
Figure 12. - Select Nodelist
 - Select nodes which covers shape. For a flat area, 4 nodes should be enough
 - Model Heat exchanger (HXs):
- When you are given detailed HXs with fins and tubes, model them
                                using boxes
- Create HXs boxes
 - Delete the fins and tubes
 - Only retain HX shroud
 - Do not include HX box components in wrapping
 - After wrapping, connect HX box and wrapped parts (required
                                        for AcuSolve only)
- Mesh pull down > Boolean
 - Select all wrapped components and HX boxes
 - Define Boxes as master > Boolean
 - Create HX boxes
Figure 13.- Mesh pull down > Hole/Gap Fill
 - Switch selection to Nodelist
 - Select four corner nodes which covers fins and tubes
 - Do it for both inlet and outlet
 - Create a side walls using same tool
 - Organize elements in appropriate components
 - Use Tools panel > Translate to enclose HX in corresponding
                                            box
Figure 14.
                                using boxes
 - Wrap setting - Mesh Controls:
- Define wrapper settings
- Mesh pull down > Mesh controls
 - Right-click > Adaptive wrap folder > Create > Model
 - Select wrapper type: external wrapper
 - External wrapper for external flow analysis, for example, underhood thermal
 - Cavity wrapper for internal flow analysis, for example, thermal comfort.
 - Select volume definition: All
- Available options (All/Nth largest/Enclosed by node/Exclude by node) – See the help for more details
 - Select components to be wrapped
 - Define wrapping parameters:
Figure 15.
 - Tips:
- Minimum size should be based on the smallest feature length to be captured. (Rule of thumb – minimum size = 1/3rd of smallest thickness)
 - If all gaps are patched using “Hole/gap fill” tool, define
                                        gap patch tolerance as minimum size.
- Defining bigger gap patch tolerance can create bad wrap mesh
 - Define local controls if any other wrapping size is required locally
 - Define Proximity Controls to avoid contacts between selected
                                    parts
Figure 16.- Define proximity controls
 - Select all HX, Air filter and neighboring shroud components
 - Define search floor. Any thing less than value will be
                                            refined
Figure 17. - Leak Detection to verify if any leaks present in the model
                                        with given selection and parameters
- Define a source node inside the wrapping domain
- Make sure source node is enclosed properly and not close by any elements
 - Define multiple target nodes outside the volumes.
- Define many target nodes and distribute them at different location
 - This way you have a greater chance of finding
                                                  all possible leaks at once
Figure 18.
 - Run wrapping:
- Right-click on adaptive wrap folder -> Mesh
 - If leak detection mesh control is defined and there is a leak, it will terminate wrapping with leak path.
 - Review wrap results:
- Review wrap results and validate it before tetmeshing. After
                                wrapping, there will be a new assembly creates which will contain
                                wrapped results
Figure 19. - Check intersections:
- 3d panel > Tetramesh > Select all wrapped components > Check 2d mesh
 - Define intersection tolerance (for mm scale 0.001 and di-hedral angle as 5)
 - Wrapped results mostly will not have any intersection.
 - But sometimes you can see few intersections which can be resolved using 2d panel > Replace
 - Check free edges and t-connection
- Tools panel > Edges > Select all wrapped components > Free edge/t-connection
 - Wrapped results should not have any free edges/t-connections
 - Analyze volume wrapper has created
- Use volume_analyser.tcl script
 - Only display wrapped components (either wrapped or remeshed)
 - It will create a sets with possible volumes and you can review each volume as well
                                wrapped results
 - Decimation:
- If solver is uFx/PowerFlow, it is required to have minimum element count for post processing purpose
 - Decimation reduces elements count retaining sharp features intact
                                with minimal geometry deviation
Figure 20.- Use Decimation scripts to coarsen mesh
- Select components to decimate
 - Define decimation factor: 0
 - 0: Provides least deviation from input
 - 1: Enables maximum possible deviation
 - Define feature angle: 30
