Cut and Stitch
Use this process to replace the upper body of the model with a modified design for repeated design iterations. This process uses Inspire Studio to generate/modify the upper body design and HyperMesh to switch/replace the designs as needed.
Figure 3.
Process
- Import the upper body as an STL from Inspire Studio. Check for and delete any duplicate
                            elements.
Figure 4. - Equivalence
                        non-conforming elements so there is only one edge along the outer boundary
                        of a surface.
Figure 5. - Import the cabin floor and apron.
Figure 6.- Ensure both the upper body and the cabin floor/apron are the same scale and intersect them as desired.
 - Scale both models to 1000*m
Figure 7. - Boolean the surfaces together.
Figure 8. - Trim unnecessary surfaces from the model.
Figure 9. - Scale to meters.
 - Import the powertrain, wheels, mirrors, and so on.
Figure 10.
