AcuSolve Run
In 2023, Compute Console also allows you to start AcuSolve. For this, the AcuSolve input file (name.inp) must match the problem name (defined in the Acusim.cnf file) and the Use solver control option should be selected. It is acceptable to select either the .inp file (name.inp) or the Acusim.cnf file (which defines problem name parameter (problem = <name>) as the input file.
When AcuSolve is executed multiple times in the same location, result file IDs are incremented. A new option on the View menu (Disk Inspector) is designed specifically for the AcuSolve runs, which allows you to inspect the content of the run folder, and optionally inspect or delete content of specific runs by their ID.
