Multiphysics Co-Simulation
- AcuSolve with OptiStruct
- AcuSolve with MotionSolve
Select Run to submit a job to the internal queue as if it was a single solver run. It is possible to mix co-simulation runs with standard runs in the queue. When the Compute Console initiates a run, the job automatically starts two solver runs, as well as the required middleware (for a MotionSolve co-simulation run). When such a job runs, two Solver View forms and two independent .log files are created. Both Solver View forms will show the options Abort, Kill, and so on, and each of them will control the corresponding single solver only.
