HgTrans translates solver results files from their native file format to Altair Binary Format (ABF). This can be done using
the HgTrans GUI or via the HgTrans batch mode.
The HWTK GUI Toolkit is a resource tool for coding Tcl/Tk dialogs. It contains documentation of the HWTK GUI Toolkit commands, demo pages that illustrate our Altair GUI standards, and sample code for creating those examples.
The Model Identification Tool (MIT) is a profile in HyperGraph for fitting test data from frequency- and amplitude-dependent bushings to analytical models. The MIT operates in conjunction with HyperGraph, MotionView and MotionSolve to provide you with a comprehensive solution for modeling and analysis.
The HyperWorks Automation Toolkit (HWAT) is a collection of functions and widgets that allows an application to quickly assemble
HyperWorks automations with minimal effort and maximum portability.
To open the options selector, select View > Solver Options Selector on the main form or click to the right of the Options
field. This will open the form shown in Figure 1 – usually containing only the most commonly
used options (unless the solver has only few options available). Select the
More options button to display all applicable
options. Figure 1. Interactive available options selector
This form contains options applicable and selective to a particular solver, so the
input file must be selected for the Compute Console first, before it is possible to
choose an appropriate set of options. After selecting any option, an additional form
appears if a value for the option is required. You can enter a value in the field,
select from the list of available options or use File Browser to
select file path as applicable. In cases where a value is optional, the ‘None’
button on the form may be used. The selection of any option automatically disables
incompatible options in the list. After options are transferred to the main form, it
is possible to manually edit the contents of this field on the main form, if required.
More options
Expands the form to show all applicable options.
Apply Selected
Copies all selected options and values to the Options line in the main
form, overwriting any existing content.
Append Selected
form, after any existing content.
Clear
Clear all selected options and values.
Close
Close the form – selected options will be retained separately for each
solver and reused until the application is closed.
Warning: Care must be taken to avoid duplicate options in
the field which will cause an error when starting the solver.
