Several tools require you to define a plane or a vector direction to perform a certain function, such as dragging
geometry along a vector, spinning it about an axis, or splitting it with a plane. The Plane and Vector tools are used to define and edit planes and directions.
Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE
studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
Define Orientation
Several tools require you to define a plane or a vector direction to perform a certain function, such as dragging geometry along a vector, spinning it about an axis, or splitting it with a plane. The Plane and Vector tools are used to define and edit planes and directions.
