When an external input translator is used to import data, the application creates a file for messages in the directory
in which the program was started.
Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE
studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
Import Error Messages
When an external input translator is used to import data, the application creates a file for messages in the directory in which the program was started.
