Altair HyperMesh CFD 2023 Release Notes
Highlights
HyperMesh CFD 2023 introduces a new solution-centric streamlined user interface which provides end-to-end workflows for aerodynamics, aeroacoustics, internal flow, multiphase flow, thermal and moving mesh simulations. A modern UI layout with intuitive workflows provides fast and robust tools for geometric modeling, case setup, post-processing, and design exploration, enabling you to carry out large complex simulations efficiently.
Solution focused user interface:
  • Seamless end-to-end workflow for aerodynamic and fan noise simulations.
  • Improved data management between discrete geometry and aerodynamics setup environments.
Geometric modeling:
  • Lite modeling environment
  • Volume refinement zone creation utility
  • Revolve region tool to create MRF regions automatically
  • CAD Wrapper improvements
    • Auto seal for CAD Wrapper
    • Local control support
    • Performance improvement
    • Robustness to get clean wrap mesh
  • Template manager improvements
  • Model organization improvements
  • Graphics performance improvements for FE geometry models
Case setup (Aerodynamics and Aeroacoustics):
  • Adaptive two-way wall model
  • Enhancements to the fan guide panel workflow
  • Accelerated import of parts from pre-processor using thread parallelization
  • Python API to run a uFX simulation
Post-processing:
  • Volume rendering added to part display properties
  • Measures: General Signal Processing (GSP) workflow for wind noise calculations
  • Engineering Calculator: Calculate uniformity index on a surface, slice plane or iso-surface
  • Vortex core: Threshold the vortex core based on vorticity magnitude or vortex core line length
  • Import STL files for geometry viewing
  • Additional colormap options are available for automatic report generation
Design exploration:
  • Morphing environment
    • Morphing tools
    • Tool for DOE studies and process automation
General
New Features
Ribbon Hints
Ribbon hints have been added to help identify tools that have multiple pick targets or open a secondary ribbon. They are small indicators that appear in the ribbon between a tool’s icon and label. The number of dots represents the number of pick targets in a tool, including some that are hidden until hovering over the tool.
To control this option, go to File > Preferences > Common > Application > Show ribbon hints.
Known Issues
  • On certain machines, when the Enter and Backspace keys are used one after the other while renaming or searching in the Part Browser, a rectangular symbol is shown in the edit field in which you are typing.
Solution Layers
New Features
A new UI layer to enable solution-centric workflows. You are able to carry out end-to-end workflows by traversing through modeling environments available in the UI. There are 3 major aspects of this UI layer:
Startup dialog
Upon invoking the application or starting a new session, a startup dialog is shown that allows you to select solutions of interest, the default modeling environment, and the startup/project directory.
The getting started tab takes you to the help documentation.
Double-click on a file in the recent files tab to open it.
Solutions
Tied to the type of simulation you are interested in. The UI layout, tools exposed, and default values are defined based on the selected solution. Either upon starting the product or on creating a new session, you can select a “Solution” in the startup dialog. If you have existing geometry/model data you want to keep for another solution, you can switch using File → Solution.
Exposes tools and ribbons to carry out external aerodynamics and fan noise simulations.
General Purpose CFD
Exposes tools and ribbons to carry out general multiphysics, thermal, and FSI simulations.
Environments
Environments are collections of tools based on modeling tasks. A modeling environment switcher is available on the ribbon bar. Selecting an environment populates relevant ribbons and tools. If data transfer is required across modeling environments, a data transfer tool is invoked to ask you about appropriate selections. Each solution can have different modeling environments.
In future release we will add further new solutions.
You can work on different modeling environments, and data management of all modeling environments or data transfer between environments is taken care of by the workflow. All data from different environments is packaged in a single file, and on opening the file data is passed to the relevant modeling environment.
Geometric Modeling
New Features
Lite modeling
Added a new way to load lite representation of CAD geometry. It affects the following workflows:
Review and grouping
You can load lite CAD representation data quickly to review large CAD files (significantly fast for .jt files), review, group, and load CAD geometry of required parts only and continue modeling. It reduces not only import time but the memory footprint as well.
Geometric model preparation
You can load lite CAD representation data using the import dialog option or convert existing FE geometry/mesh data to lite representation data using the “Convert” tool. Once data is converted to lite rep, you can utilize most tools in the “Discrete” ribbon to prepare the model, such as wrapping, remeshing, decimation, and so on. The memory footprint of lite rep is significantly smaller compared to CAD or FE geometry data.
Directly mesh CAD parts in batch mode
You can load lite CAD representation data quickly to review large CAD files → define part controls (meshing settings) in the Assembly ribbon → go to the Representation tool, select “Create Representation” option, select parts to mesh, and click execute. This submits meshing jobs in batch mode and returns mesh once done. Selected parts needs to have CAD representation saved.
A new tool “Derived Region” is added to create volume refinement zones and projected mesh. You can create the following regions using this tool:
Enclosed region: Enables you to create refinement zones enclosing selected parts with specified offset distance.
Offset region: Enables you to create refinement zones by offsetting selected parts with specified offset distance.
Projected region: Creates a mesh by projecting inputs on specified direction. Useful for calculating frontal area.
Revolve region
A new tool to create an MRF region automatically around a selected solid part is added. You can specify offset distance. You have the option to get the revolved solid as output or a spin surface. With the “Spin Surface” option, you can edit/simplify the surface and then revolve it manually.
Enhancements
CAD Wrapper has significant improvements in terms of new features, robustness and performance. The following are major or improvements:
Auto seal
A new option in CAD Wrapper to patch openings automatically. One of the big tasks pre-wrapping is to close gaps smaller than the gap tolerance. This can be a time consuming process. With the “Auto seal” option enabled, you can patch big holes automatically using the “Hole Cap” tool and submit CAD Wrap. Another advantage is you can define a very small gap tolerance (for a car model, around 6 mm) and still get a water tight model without any manual efforts.
CAD Wrap now supports local controls for mixed and lite types as well. You can select parts and define local sizes controls in the “Local” tool and those settings are enforced in the wrapping process.
With this release we are seeing 20% - 30 % performance improvements for car models compared to previous release.
In previous builds, you still had free edges and non-manifolds after wrap. With improvements, you should not see free edges and non-manifolds in most cases.
The template manager has gone through a lot of new improvements:
  • Supports part name-based, part metadata-based grouping
  • New operations: “Bulk Operation”, “Auto cleanup” and “Volume refinement” added which help to automate aerodynamic modeling.
With these changes, it will be possible to automate full vehicle geometric modeling process. Also reorganized selection.
Added a new option in the right-click menu to organize elements to any parts. Also added capability to split mesh parts based on connectivity which helps to split models which come as a single part.
Graphics performance improvement for FE geometry model
FE Geometry data type rendering performance is improved significantly to make rendering options like show/hide/isolate, selection - deselection instant. Operation performance is improved as well.
Case Setup
New Features
A new “adaptive two-way” wall model coupling is introduced which replaces the old “two-way” wall model coupling as the default.
The global default can be reset to “two-way” from the Model Browser by selecting the active model. Wall model for individual parts can be reset to either “two-way” or “one-way”.
Enhancements
Fan Guide Panel
The fan cylinder dimensions are more robust to changes.
  • For larger models where computing the volume takes time, a busy cursor is displayed to inform you.
  • Overset cylinder volume is centered on adjusting the height.
  • Solid revolution volume creation is retried with multiple tolerances for enhanced robustness.
Python API
New API has been created to help you set up a simulation and run the solver in the same script. You can invoke vwt.RunUfx(runDir) from the Python window to run the simulation on a Linux machine with a compatible GPU.
Units Import Dialog
The import dialog for unit selection has been updated to allow you to interact with the model before choosing the units.
Resolved Issues
  • XML import/export errors have been fixed for:
    • Fan template with overset volume
    • Section cuts
  • Fan cylinder volume dimensions requested by user are respected. Additional padding is no longer applied.
  • Fan refinement element size is updated consistently.
  • Undo/Redo works correctly for fans with Overset/MRF volumes.
  • Units import in mm does not affect material properties.
  • Section cut visibility works consistently.
  • Default rotation axis for fans is right-handed.
  • ufxRun script has been updated to reflect new GPU driver requirements and obsoletes the basicMesh utility.
  • Monitoring surfaces can be created from Python API without errors.
Post-Processing
New Features
Volume rendering is useful for interpreting three-dimensional data from within a simulation volume, at the Part level. The tool provides the capability to interrogate the flow beyond other derived representations that are computed from a subset of the volume. For optimized calculations, the part volume is sampled to a cartesian grid as specified on a given number of sample points in X, Y, Z.
  • Three dimensional representations of the fluid flow field to interpret simulation results
    • Using scalar coloring and
    • Transparency transfer function
  • Beneficial to identify complex flow structures,
    • vortices,
    • turbulent eddies,
    • shock waves
  • Enables the identification of important features in the flow,
    • separation zones,
    • recirculation regions,
    • boundary layer thickness
Measures: General Signal Processing (GSP) for aero-acoustic calculations
GSP is needed to post-process the outputs of a CFD simulation for the purposes of computing the aeroacoustic signature of a point probe or a surface of interest. Adequate measurement files are to be computed by the solver for specific surfaces or slice planes. The files are then sent to the GSP algorithm to compute the sound pressure level from the provided point or surface.
  • Point probe workflow – signal processing of one or more points from a surface or volume to compute sound pressure level or power spectral density of the input signal.
  • Surface based workflow – signal processing of a single surface or slice plane to compute sound pressure level.
    • Hydrodynamic dB map (dB Map)
    • Band Filtered Animation (BAFA)
  • Storage of pressure vs. time for a surface to a compact HDF5 file.
    • Utilization of the GSP algorithm after the input has been pre-processed and stored to GSP file (.gsph5).
    • Capability to load the GSP file independent the original .h3d source file.
Engineering Calculator: Calculate uniformity index on a surface, slice plane, or iso-surface
You may calculate the uniformity index (UI) for a specified variable on an entity of interest (slice plane, boundary group, Iso-Surface). The UI represents the amount of local variation from the average value of the specified variable on an entity in a normalized quantity.
Vortex cores may be limited after they are computed from the display properties microdialog. Two options for clipping the vortex cores are available:
  • Vorticity magnitude – Normalized vorticity magnitude. Value of vorticity magnitude/maximum vorticity magnitude for the calculated vortex core entity.
  • Vortex core length – Normalized vortex core length. Value of vortex core length/maximum vortex core length for the calculated vortex core entity.
Ability to open/import .stl files into the post session. This capability allows you to import tessellated geometry, alleviating the need to store boundary specific information to volume results files, which is particularly useful when animating slice planes, volume subsets of the full data, and other lightweight datasets. Slice planes and portions of the full fluid volume do not contain surface blocks and therefore require a subsequent dataset to be used as reference and to ground the flow solution around a geometric entity.
Enhancements
Additional Colormap support in HWCFD Report
New colormap options are provided during automatic report generation. HMCFDReport includes the ability to define the colormap_name attribute for each display representation. The usage is as follows: colormap_name = "Color map key word", where "Color map key word" is specified in accordance with the string as written in the legend display properties. The legacy colormap from AcuFieldView has been added to support coloring entities with the same colormap, identified as “Rainbow Legacy”. For example, colormap_name="Rainbow Desaturated" or colormap_name="Cool to Warm (Extended)".
Vector components available in Engineering Quantities
Engineering quantities: Vector components, including the magnitude of the vector is now available for usage in each of the engineering quantity types.
Automatic computation of normals Boolean
When loading data in post, under the General reader, “Enable computing normals” Boolean flag has been added. If true (default condition), the automatic computation of the surface element normals is included. If False, the element normals computation is not made unless required by the requested representation. This allows for an approximately 25% improvement in time-step read times compared to when the setting is set to true.
Traveling Vectors Animation
“Animate only vectors” has been added to the streamline animate tool to display and provide an animation of traveling vectors. When utilized, the streamlines are hidden automatically, and vector glyphs are drawn along the streamlines at a frame dependent location determined by the number of frames defined in the animation toolbar. Note, when the subset option is used in the streamline vector display options, more or fewer vector glyphs are drawn along the streamline.
Design Exploration
New Features
A new “Morphing” ribbon is added to morph mesh or FE geometry. You can define constraints to fix some nodes or define relative movement. You can morph mesh with different approaches:
  1. Interactive morph: Use “Free” or “Proximity” tools and morph mesh by selecting nodes /elements interactively.
  2. Morph volumes: Define Morph Volumes, manipulate handles to make morph volume body fit to mesh, morph mesh by manipulating morph volume handles, edges, or faces.
Once morphing is done, you can create shapes and design variables using the “Shape” tool and submit DOE studies using “DOE Study” tool. The “DOE study” tool can be used for shape, CAD parameters, DOEs, and also for automation.
