<simulation>
The <simulation> category specifies the main parameters of the simulation like the number of iterations, and the file containing the surface mesh or the fluid material.
<simulation> - <general>
The <general> category contains the following parameters:
<num_coarsest_iterations>
Defines the number of iterations at the coarsest refinement level. The physical time per coarsest iteration depends on the material parameters and the Mach factor.
<mach_factor>
Specifies the scaling factor for the Mach number (1.0 = Mach-matched simulation). The time step increases linearly with this factor. With a value of 2.0, for example, the simulation runs approximately twice as fast for the same simulated physical time.
Note: ultraFluidX is using a weak compressible LBM formulation, which is only valid up to approximately Ma = 0.4, so consider the maximum velocity that may occur in your simulation when setting this parameter to not exceed this limit.
Default = 1.0
<moving_ground>
The wind tunnel ground is a no-slip wall with zero velocity by default. If it should be moving with <reference_velocity> instead, the parameter must be set to true. If belts are specified (<boundary_conditions>), only the belts will move, not the whole ground.
<rotating_wheels>
By specifying this parameter, all rotating boundary conditions (<boundary_conditions>) can be switched on or off at once. If set to false, all entries in the <rotating> category will be effectively ignored.
<boundary_layer_suction>
Specifies if a part of the wind tunnel ground starting from the inlet to <boundary_layer_suction_xpos> should be treated as a slip wall, instead of a no-slip wall.
Specifies the x-coordinate (in [ m ] ), where the slip wall will end, if <boundary_layer_suction> is set to true.
The reference velocity (specified in [ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@ ) is used as velocity at the inlet. It is also used as wall velocity for any belts (if specified) or for the whole wind tunnel ground and for the calculation of the aerodynamic coefficients.
<simulation> - <geometry>
ultraFluidX introduced an alternative to (STL-) part-based syntax for the definition of boundary conditions. The default axis-aligned domain boundary conditions are converted to the new part-based format via automatically created default domain parts:
  • - uFX_domain_x_min
  • - uFX_domain_x_max
  • - uFX_domain_y_min
  • - uFX_domain_y_max
  • - uFX_domain_z_min
  • - uFX_domain_z_max
The parts are automatically created in ultraFluidX and do not need to be specified in the input STL file. The part names are reserved and cannot be used for other (STL) parts.
Note: The Altair Virtual Wind Tunnel does not support the specification of domain parts yet. VWT still creates solver decks with the original definition of boundary conditions. These case setups will be automatically converted to the new part-based syntax by the ultraFluidX solver.
Note: Effective solver decks that are written by recent versions of ultraFluidX contain the updated part-based syntax and cannot be imported into the Virtual Wind Tunnel.
Note: The new part-based boundary conditions are based on a new LBM boundary treatment with full support of the ultraFluidX wall models. The old domain boundary treatment is still possible if you explicitly set “link_based_bc=false” on all individual parts as well as all reserved ultraFluidX domain parts.
The <geometry> category contains the following parameters:
<source_file> or <source_files> - <name>
Specifies the path to the source file(s) that contain(s) the tessellated surface mesh. The source file(s) must be in ASCII STL format and all surface normals must point outwards, that is, from solid to fluid. ultraFluidX assumes that the STL file is specified in [ m ] and all other coordinates for bounding boxes, probe locations, etc. are based on the coordinate system of the STL.
While <source_file> (without an additional <name> parameter) is used for cases where the complete surface is available in a single STL file, the category <source_files> allows to specify more than one input file, each filename being indicated under the parameter <name>.
Warning: If parameters, <source_file> and <source_files> are specified simultaneously, the run will stop.
<baffle_parts>
(Optional) Specifies all parts which are fully two-dimensional, each part with this property must be identified via the child parameter <name>. This property should be set for parts which do not form a closed volume together with other parts and which are expected to be connected to fluid regions on both sides. ultraFluidX will then internally create a duplicate of each of the parts with the appendix “_inv” and inverted triangle normals to be able to assign proper pressure and wall shear stress values to both sides of the part.
CAUTION:
Only specify this property for the baffle part; otherwise, unwanted side effects might occur.
<surface_mesh_optimization> - <triangle_splitting>
Specifies the triangle splitting to increase the accuracy of the calculation of aerodynamics forces that act on the surfaces. Either global or local splitting can be selected. The default setting is global, controlled by the following child parameters:
<active>
(Global) Switch that activates the triangle splitting.
Default = True
<max_relative_edge_length>
This factor multiplies the voxel size connected to the geometric part to compute the splitting threshold. Setting this factor to zero makes the variable inactive. Negative values are corrected to zero. If this parameter and <max_absolute_edge_length> are both greater than zero, the smaller value per part has precedence.
Absolute threshold (in [m]) of splitting. Default values is set to zero and hence inactive. Negative values are corrected to zero. If this parameter and <max_relative_edge_length> are both greater than zero, the smaller value per part has precedence.
Alternatively, the triangle splitting can be activated only on certain parts of the geometry with the <triangle_splitting_instance> category with the following parameters:
<name>
(Optional) Name of the instance.
<active>
Same as the global parameter but for local setting; has precedence over global setting.
<parts>
Specify the parts on which the local settings of the splitting are applied via the child parameter <name>. Several parts can be specified via repeated usage of <name> to assign the local settings to all of them. Part names must be valid and not repeated in the same or other instances, or the run stops.
Note: Old triangle splitting parameters are still supported. However, the new triangle splitting category has precedence over it.
<triangle_plinth>
ultraFluidX automatically creates a plinth in regions where single voxels would be squeezed between the wind tunnel ground and, for example, the tire of a car by treating such single voxels as solid. If <triangle_plinth> is set to true, the corresponding surface triangles of these solid voxels will be created to properly visualize the behavior and to increase the accuracy of the calculation of aerodynamic forces in that region.
<domain_bounding_box>
The bounding box of the simulation domain, must be specified via the child parameters <x_min>, <x_max>, <y_min>, <y_max>, <z_min> and <z_max> in [ m ] .
ultraFluidX currently needs the domain size in each direction to be a multiple of four of the <coarsest_mesh_size>. Therefore, the bounding box is automatically enlarged in +x-direction, +z-direction and symmetrically in y-direction if the requirement is not met.
<simulation> - <material>
The <material> category is used to describe the properties of the fluid material that should be assumed for the simulation, for example, air, and contains the following parameters:
<density>
Density ρ MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyWdihaaa@37B3@ of the material [ kg m 3 ] .
<dynamic_viscosity>
Dynamic viscosity μ MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqiVd0gaaa@37A9@ of the material [ kg (s · m) ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada WcaaqaaiaabUgacaqGNbaabaGaaeikaiaabohacqWIpM+zcaqGTbGa aeykaaaaaiaawUfacaGLDbaaaaa@3F7D@ .
<temperature>
Temperature (T) of the material [ K ] .
<specific_gas_constant>
Specific gas constant (R) of the material [ J kg⋅K ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeaaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada WcaaqaaiaabQeaaeaacaqGRbGaae4zaiabgwSixlaabUeaaaaacaGL BbGaayzxaaaaaa@3DB3@ .
<simulation> - <wall_modeling>
ultraFluidX allows you to specify the handling of near wall regions of the flow using the following parameters:
<coupling> (adaptive_two-way, two-way,one-way, off)
This parameter exposes coupling options of how to impose wall shear stress with the velocity at a donor node, given by the LES computation. Further past the region, the IBB wall boundary condition is updated with a slip velocity that enforces the target wall shear stress. This wall shear stress is calculated by supposing that the donor velocity away from the wall verifies a given theoretical law of the wall, for example, like the classical log law; see the <wall_model> parameter below. Different choices for this coupling are available in ultraFluidX:
adaptive_two-way
The adaptive two way wall-LES coupling model imposes the right near wall slope of velocity as well as the right wall eddy viscosity based on the different information collected in the wall vicinity and the chosen law of the wall. This is the latest coupling model. If adaptive_two-way is specified, the bounding walls (excluding inlet and outlet) are automatically defined as link-based (link_based_bc).
two-way
The wall shear stress determined using the wall model is used as an input value for the computation of the slip velocity at the wall.
one-way
The slip velocity at the wall is not derived via the wall shear stress. It is based on information at the donor position and coming from the LES in the bulk flow and is directly proportional to this value (non-homogeneous Dirichlet for the velocity). The wall shear stress determined by this coupling approach is computed a posteriori, for instance to be used for the estimation of the viscous force contribution.
off
No wall model is used with this parameter. It falls back to the classical no-slip boundary condition (homogeneous Dirichlet for the velocity). The wall shear stress determined by this coupling approach is computed a posteriori, only to be used for the estimation of the viscous force contribution.
<wall_model> (GLW, GWF, WangMoin, off)
This parameter specifies which theoretical law of the wall should be used in conjunction with adaptive_two-way or two-way coupling methods in order to perform an actual Wall Modeled Large Eddy Simulation (WMLES). Available options:
GLW (Default for adaptive_two-way coupling method)
The generalized law of the wall is a continuous function of y MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyEaaaa@36F4@ + and of the streamwise pressure gradient (adverse only, <pressure_gradient> is automatically set to adverse; the only other option is off.) It has the correct trend for small y MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyEaaaa@36F4@ +; a fine enough mesh is necessary to capture this region correctly. More details are given in reference [1] and [2] .
GWF (Default for two-way coupling method)
The Generalized wall function is a set of two piecewise-defined functions, one depending on y MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyEaaaa@36F4@ + and the other depending on y MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyEaaaa@36F4@ c where the velocity scale u c MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyDaSGaam 4yaaaa@37E3@ is a mix of the friction velocity and a velocity scale based on the full pressure gradient (<pressure_gradient> is automatically set to adverse; favorable, adverse and off are the alternative options.) More details are given in reference [3].
WangMoin
The law of the wall function is not given explicitly but rather a simplified turbulent boundary layer equation (TBLE) where a given pressure gradient is solved for. More details are given in reference [4] and [5].
off
The acceptable combinations when using the various coupling methods are shown below. The shaded blue boxes indicate default combinations. The line indicates the allowed combination.
Adaptive Two-Way Coupling (default)
*With ATW, if GWF is applied, the default pressure gradient is full.
** With ATW, if GLW is applied, the option of pressure gradient off is acceptable.
Two-way coupling
One-way coupling
Figure 3.
Coupling off
Figure 4.
<pressure_gradient> (favorable, adverse, full, off)
It is possible to specify the way in which pressure gradients along the wall should be considered by the wall model.
off
The wall model will not consider pressure gradients present in the mean flow field and determine the wall shear stress neglecting the respective pressure-gradient term.
favorable and adverse
Consider negative and positive pressure gradients in direction of the flow, respectively.
full
Takes any pressure gradient near the wall into account.
<simulation> - <wall_model_variant>
You can specify different wall model settings apart from the global default (specified via <simulation> - <wall_modeling>) on different parts of the vehicle.
For this purpose, an arbitrary number of such different wall model settings can be specified as children of <wall_model_variant> via <wall_model_variant_instance>, each with the following parameters:
<name>
Name of the instance, so that it can be referenced in the respective <rotating_instance> or <static_instance> to which it should be applied (mandatory).
See above in <simulation> - <wall_modeling>.
<coupling> (adaptive_two-way, two-way, one-way, off)
Note: The use of wall model variants is currently not supported in overset mesh regions. The wall model within the overset regions is globally specified in <simulation> - <wall_modeling>.
1 Shih, T. H., Povinelli, L. A., & Liu, N. S. (2003). Application of generalized wall function for complex turbulent flows. Journal of Turbulence, 4, 015
2 Wang, M., & Moin, P. (2002). Dynamic wall modeling for large-eddy simulation of complex turbulent flows. Physics of Fluids, 14(7), 2043-2051
3 E. Lévêque, H. Touil, S. Malik, D. Ricot and A. Sengissen, "Wall-modeled large-eddy simulation of the flow past a rod-airfoil tandem by the Lattice Boltzmann method," International Journal of Numerical Methods for Heat and Fluid Flow, vol. 28, p. 1096–1116, 2018.
4 J. Boudet, E. Lévêque and H. Touil, "Unsteady Lattice Boltzmann Simulations of Corner Separation in a Compressor Cascade," Journal of Turbomachinery, vol. 144, September 2021.
5 T.-H. Shih, L. Povinelli and N.-S. Liu, "Application of generalized wall function for complex turbulent flows," vol. 4, Informa UK Limited, 2003.
6 W. Cabot and P. Moin, "Approximate Wall Boundary Conditions in the Large-Eddy Simulation of High Reynolds Number Flow," Flow, Turbulence and Combustion, vol. 63, p. 269–291, 2000.
7 M. Wang and P. Moin, "Dynamic wall modeling for large-eddy simulation of complex turbulent flows," Physics of Fluids, vol. 14, p. 2043–2051, 2002.
