Load Map
The event setup section is defined within this tag.
The load map section is defined within:
<LoadMap>
</LoadMap>
Element Tag Valid Values Comment
<LoadMapFile> Valid file path Applicable for Duty cyle (.dcy) file
Applicable for LoadMap (.xml) file
<Channel> <tabfat> Mandatory
<FatigeEvents>
<Event>
<Fatload>
Mandatory
<Fatseq> <Fatevnt> Mandatory
Time Series
Time Data Channels are defined as:
<Channel>
      <tabfat id="1" type="Time Data">D:/Sample_Load_path/load1.csv</tabfat>
    </Channel>
Table 1. <tabfat> Attributes
Attribute Valid Values
id Valid ID
type "Time Data"
<tabfat> Valid load-history file path
Define the Event
<FatigeEvents>
   <Event Configuration="superposition" Gate="0" id="1" name="Event_1">
       <Fatload LDM="1" Offset="0" Scale="1" block="1" resultfile="" sim="" subcase="1" tabfatId="1" tabfatName=""></Fatload>
</Event>
</FatigeEvents>
Table 2. <Event> Attributes
Attribute Valid Values Comment
Configuration "superposition" Mandatory
Gate 0 < Value < 1.0 Mandatory
id Valid ID Mandatory
name Valid name Mandatory
<Event> is defined with <Fatload>.
Table 3. <Fatload> Attributes
Attribute Valid Values Commend
LDM LDM should be a non-zero value Mandatory
Offset Valid value Mandatory
Scale Scale should be a non-zero value Mandatory
block Valid value Mandatory
resultfile NA Reserved for later use
sim Valid value Mandatory when simulation list from subcase is present
subcase Valid value Mandatory
tabfatId Valid value Mandatory
tabfatName NA Reserved for later use
<Fatseq>
      <Fatevnt EventId="" EventName="Event_1" Repeats="1"></Fatevnt>
    </Fatseq>
Table 4. <Fatevnt> Attributes
EventId Valid value Either event id or name is Mandatory
EventName Event name
Repeats Valid value Mandatory
Transient
Transient events are defined as:
<FatigeEvents>
    <Event id="1" name="Event_1">
        <Fatload resultfile="" subcase="1"></Fatload>
    </Event>
</FatigeEvents>
Table 5. <Event> Attributes
Table 6. <Fatload> Attributes
<Fatseq>
</Fatseq>
Table 7. <Fatevnt> Attributes
EventName Event Name
Modal Superposition
Modal superposition channels are defined as:
<Channel>
      <ModalParticipationFactorFile>File_path</ModalParticipationFactorFile>
    </Channel>
<ModalParticipationFactorFile> Valid file path (.pch/.mrf)
Define the Event
<FatigeEvents>
        <Event id="1" name="ModalEvent_1">
            <Fatload modal_channel="Subcase 1" resultfile="" sim="" subcase="1" tabfatId="" tabfatName=""></Fatload>
         </Event>
Table 8. <Event> Attributes
id Valid ID
name Valid event name
Table 9. <Fatload> Attributes
modal channel Valid Subcase name Mandatory
<Fatseq>
         <Fatevnt EventId="" EventName="ModalEvent_1" Repeats="1"></Fatevnt>
    </Fatseq>
Table 10. <Fatevnt> Attributes
Random - PSD Stresses
Random events are defined as:
<FatigeEvents>
      </Event>
    </FatigeEvents>
Table 11. <Event> Attributes
Table 12. <Fatload> Attributes
<Fatseq>
    </Fatseq>
Table 13. <Fatevnt> Attributes
Random - Input PSD with FRF
Random analysis channels are defined as:
<Channel>
      <tabfat id="1" type="Input PSD:Real - Imaginary"> Fatigue_InputPSD/Input_PSD.csv</tabfat>
    </Channel>
Table 14. <tabfat> Attributes
id Valid ID
type Constant Amplitude
<tabfat> Valid material file path
Define the Event
<FatigeEvents>
        <Fatload Excitation1="1" Excitation2="1" resultfile="" sim="" tabfatId="" tabfatName=""></Fatload>
        <Fatload Excitation1="1" Excitation2="2" resultfile="" sim="" tabfatId="" tabfatName=""></Fatload>
        <Fatload Excitation1="2" Excitation2="2" resultfile="" sim="" tabfatId="" tabfatName=""></Fatload>
      </Event>
    </FatigeEvents>
Table 15. <Event> Attributes
Table 16. <Fatload> Attributes
Excitation1 Valid value Mandatory
Excitation2 Valid value Mandatory
sim NA Reserved for later use
tabfatId Valid value Optional
<Fatseq>
      <Fatevnt EventId="" EventName="Event_1" ExposureTime="1"></Fatevnt>
    </Fatseq>
Table 17. <Fatevnt> Attributes
ExposureTime Valid value Mandatory
Sine Sweep
Sine Sweep analysis channels are defined as:
<Channel>
      <tabfat id="1" scale="0.1" type="Constant Load"></tabfat>
    </Channel>
Table 18. <tabfat> Attributes
id Valid ID
scale Scale should be a non-zero value (NA for Variable Scale)
type
"Constant Load"
"Variable Scale"
<tabfat> Valid file path (NA for Constant load)
Define the Event
<FatigeEvents>
        <Fatload resultfile="" sim="" subcase="3" sweeprate="1" sweeprateunit="HZPSEC" tabfatId="1" tabfatName=""></Fatload>
      </Event>
    </FatigeEvents>
Table 19. <Event> Attributes
Table 20. <Fatload> Attributes
sweeprate Valid value Mandatory
sweeprateunit
"HZPSEC"
"OCTPMIN"
Mandatory
tabfatId Valid ID Mandatory
tabfatName Valid name NA
<Fatseq>
      <Fatevnt EventId="" EventName="Event_1" sweeps="1"></Fatevnt>
    </Fatseq>
Table 21. <Fatevnt> Attributes
sweeps Valid value Mandatory
