Eurocode 3 Classification Parameters (Non-Welded)
The parameters for non-welded calculations are listed in both the Assign Material tab and the My Material tab of the Assign Material dialog.
The defaults are with respect to material = steel.
The following are the parameters listed in the Assign Material tab.
| Parameter | Description |
| Size Effect ( ) | default = 1.0 |
| Temperature Factor ( ) | default = 1.0 |
| Surface Treatment ( ) | default = 1.0 |
| Safety Factor for Strength ( ) | default = 1.0 |
| Loading Factor ( ) | default = 1.0 |
The following are the parameters listed in the My Material tab.
| Detail Category for nominal ( , Basic) | Listed in SN tab (default = 160 N/mm2) |
| Detail Category for shear ( , Basic) | Listed in SN tab (default = 100 N/mm2) |
| Number of cycles at Constant Amplitude Fatigue Limit – nominal ( ) | Listed in SN tab (default = 5e6 cycles) |
| Number of cycles at Cut-Off Limit – nominal ( ) | Listed in SN tab (default = 1e8 cycles) |
| Slope before Constant Amplitude Fatigue Limit – nominal ( ) | Listed in SN tab (default = 3.0) |
| Slope before Cut-Off Limit – nominal ( ) | Listed in SN tab (default = 5.0) |
| Number of cycles at which the reference value of the fatigue strength is defined. (greyed out) – nominal ( ) | Listed in SN tab (default = 2e6 cycles) |
| Number of cycles at Cut-Off Limit – shear ( ) | Listed in SN tab (default = 1e8 cycles) |
| Slope before Constant Amplitude Fatigue Limit – shear ( ) | Listed in SN tab (default = 5.0 ) |
| Number of cycles at which the reference value of the fatigue strength is defined – shear ( ) | Listed in SN tab (default = 2e6 cycles) |
Formulation
- Query Stress , , (max and min across all loadcases)
 - Find the stress ranges (max – min) = ( , , and )
 - Multiply Stress Range from Loading Factor
 - Calculate Corrected Fatigue Strength and
 - Calculate Constant Amplitude Fatigue Limit and
 - Calculate Stress at Cut-off Limit and
 - Calculate Permissible Number of Cycles
 - Component Damage
 - Equivalent Damage
EN 1999-1-3:2011-11 (November
                        2011). Permission to use and reproduce information contained in the
                    Eurocode 3 standards was granted by DIN.
