hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Averages the element integration point results to element values.
Averages the element node-on-element results to nodal values.
Sets the status of an element to active or inactive.
Assigns a value to counter.
Sets the status of a node to active or inactive.
Assigns a value to the counter.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
ON THIS PAGE
ON THIS PAGE
