hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Closes hmmodlib.
Divides the value field in the element structure by the counter field.
Assigns all of the maximums associated with all the elements in the model to a user-specified value.
Resets the value and counter values in the element data structure.
Initializes hmmodlib.
Divides the value field in the node structure by the counter field.
Assigns all of the maximums associated with all the nodes in the model to a user-specified value.
Resets the value and counter values in the node data structure.
Writes a model that can be read by HyperMesh.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
ON THIS PAGE
ON THIS PAGE
