hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Retrieves the pointer to an element.
Retrieves the pointer to an element if it exists.
Retrieves a pointer to the first element stored in hmmodlib.
Retrieves a pointer to the next element stored in hmmodlib.
Retrieves a pointer to a node.
Retrieves the pointer to a node.
Retrieves the pointer to a node if it exists.
Retrieves a pointer to the first node stored in hmmodlib.
Retrieves a pointer to the next node stored in hmmodlib.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
