Gets an animator handle of a page.
Gets a client handle.
Gets a file handle.
Gets a movie handle.
Gets a note handle of a window.
Gets a page handle.
Gets the project handle.
Gets the session handle.
Gets the Templex handle.
Gets a ViewControl handle of a window.
Gets a window handle.
ON THIS PAGE
ON THIS PAGE
