::hwp::GetWindow
Gets a window handle.
::hwp::GetWindow
Tcl Query
This procedure implements minus options.
This procedure returns a window handle of HyperGraph/HyperView/MotionView.
If no page ID is requested, then it operates on the current/active page.
If no window ID is given, then it returns the active window of the requested (or active) page.
The option "-byHandle" is an exclusive option (no other minus options are allowed).
Mandatory Arguments
None.
Optional Arguments
- -page "pageID"
- The page ID of the requested page.
- -window "windowID"
- The window ID of the requested window.
- -byHandle "handle"
- A handle created with this tool and contains a page and window ID.
Returns
Returns a window handle.
set activeWindowHandle [::hwp::GetWindow]
