HM_tableclear()
Clears the table of all stored items.
void HM_tableclear(void);
HyperMesh hmlib Function
See HM_tableadd() and HM_tablelookup().
None.
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
For an element configuration, this function returns the number of nodes that the element uses. For rigidlinks and RBE3s, this function returns 0 because these elements have a variable number of nodes.
Returns the HyperMesh #defined type number of an entity, given its name.
Returns the name of an entity, given the HyperMesh #defined type number.
Returns the HyperMesh #defined type number of an entity, given its #defined name.
Returns the string associated with the HyperMesh #defined entity, given the type number.
Reads information from a binary file.
Writes information to a binary file.
Gets the hardware size of a float.
Gets the hardware size of an integer.
Identifies the type of machine on which the program is currently running.
Prints a message on the screen.
Tracks the version number of the translator.
Sets a pointer to a function that is called by HM_terminate().
Adds an item to the table.
Retrieves a previously stored value.
Terminates a program.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
None.
