Gets the number of columns in the data extractor.
Gets the number of rows in the data extractor.
Gets the number of values in the data extractor.
Gets dependency list (data sources) from the extractor.
Gets the data values from the extractor.
ON THIS PAGE
ON THIS PAGE
