Gets the style of the animation cursor.
Gets the thickness of the animation cursor.
Determines if the color of the animation cursor is the same as the curve it is on.
Determines whether the style of the animation cursor bar (if it has a bar) is the same as the curve.
Gets the height (a percentage of the window) of the animation cursor bar.
Sets the style of the animation cursor.
Sets the thickness of the animation cursor.
Determines if the style of the animation cursor bar (if it has a bar) is the same as the curve.
Sets the height (a percentage of the window) of the animation cursor bar.
