Zooms into the given rectangle.
Unzooms video or image.
Zooms into the X dimensions of the video.
Memorizes the current view of the video.
Centers plot based on the chosen point.
Sets the current view to the view memorized with M1.
Sets the current view to the view memorized with M2.
Recenters video or image.
Translates the contents of the current window to the given position.
Moves the axes up, down, left, or right, based on the given string input.
Zooms into the video.
Zooms out of the video.
ON THIS PAGE
ON THIS PAGE
