vidIViewControl FitY
Zooms into the X dimensions of the video.
hwIViewControl_handle FitY
Tcl Modify
This command zooms into or out of the graph, based on the original X dimensions of the video in the window.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetViewControlHandle vc;
vc FitY;
Returns success (0) or an error code.
