11.0.130 API Programmer's Guide
New Commands
- Collision
- Connectors
- Display
- General/Core
- hm_batchexportenginefile
- hm_getcardimagetype
- hm_getcardimagetypemark
- hm_getboundingbox_predefined
- hm_getincrementalname
- hm_measureshortestdistance
- hm_measureshortestdistance2
- *cleanupmodelfile
- *solverdeckcleanup
- Geometry
- Graphics
- *setgraphictranslation
- *setreviewbymarkenhanced
- GUI
- HMASCII
- hminlib
- Meshing
- hm_getqephtimestep
- *blmesh_2d_computeblthickness
- *blmesh_2d_input_nonbl
- *blmesh_2d2
- *elementqualitymodifyhole
- *elementqualityoptimizenode1
- *elementqualityplacenode1
- *extend_elements
- *getunmeshedsurfstomark2
- *imprint_elements
- *midsurfmesh
- *section_plane_mesh
- Template Functions
Modified Commands
- Connectors
- hm_ce_errorreport - Returns a list for both single and multi-valued return lists.
- Data names
- bar3 - shortestside data name now properly returns the shorter of the 2 segments, and longestside data name now properly returns the longer of the 2 segments.
- General/Core
- hm_entityinfo - Added new option graphictranslation.
- hm_getincludes - Added new option -byshortnamealwaysmergeflagpair.
- hm_getoption - Added new option outputtimeinfo.
- hm_info - Added new options cardprev_displayed and reviewmode.
- hm_createmark/hm_appendmark/*createmark/*appendmark - Support has been added to the "by box", "by cylinder" and "by sphere" methods for blocks, connectors, groups and sets.
- Geometry
- *geomoutputdata - Added new argument cad_optimize. Existing scripts will default this value to 0 if not specified. *iges_write_units - Added new argument cad_optimize. Existing scripts will default this value to 0 if not specified.
- GUI
- hm_framework - Added before_menudraw, after_menudraw and erase_userpanel as event types to getregisteredprocs, registerproc and unregisterproc options. Added new option getgraphicsclick.
- Manufacturing
- *hf_FillDoubleAttachedPart - Redesigned completely with new arguments.
- Meshing
- *elementtestfree1d - Nodes are now also supported as a valid entity type.
Deprecated Commands
- Meshing
- *elementqualityoptimizenode - Use *elementqualityoptimizenodenew instead.
- *elementqualityplacenode - Use *elementqualityplacenodenew instead.
Removed Commands
- Manufacturing
- *hf_CheckDieModuleElements
- *hf_CreateAutomaticTL
