*createlistbypathpanel
Provides a widget to create an ordered list of entities for use in a subsequent command, with the collector set to "by path".
*createlistbypathpanel entity_type list_id message
HyperMesh Tcl Modify Command
- entity_type
- Entity type to put on the list. Valid values are:
- elems
- laminates
- lines
- nodes
- plies
- surfs
- list_id
- The ID of the list to populate. Valid values are 1 and 2.
- message
- A string indicating a message to display in the status bar.
Examples
*createlistbypathpanel nodes 1 "Select nodes for the line:"
set node_list [ hm_getlist nodes 1 ];
if { ! [ Null node_list ] } {
*linecreatefromnodes 1 0 150 5 179
# Handle error
}Version History
11.0.130
