*elementqualityplacenodenew
Moves the specified node to a target point.
*elementqualityplacenodenew node_id x y z normal_flag boundary_flag midnodes_flag
HyperMesh Tcl Modify Command
This command moves the specified node to a target point.
This command only functions between an *elementqualitysetup command and an *elementqualityshutdown command.
- node_id
- The node ID.
- x
- The x-coordinate of the target point.
- y
- The y-coordinate of the target point.
- z
- The z-coordinate of the target point.
- normal_flag
- 0 - Allow movement along the surface.
- boundary_flag
- 0 - Allow movement within the boundary.
- midnodes_flag
- 0 - Do not consider neighboring mid-nodes during optimization.
*createmark elems 1 displayed
*elementqualitysetup 1
*elementqualityplacenodenew 102 10.0 5.0 0.0 1 0 0
*elementqualityshutdown 1
# Handle error
Version History
12.0.110
