HM_free()
Frees a block of memory.
void HM_free(void * ptr);
HyperMesh hmlib Function
- ptr
- A pointer to a block of memory.
If *ptr is NULL, HM_free() does not perform any operation.
None.
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Allocates a block of memory and clears it to zero.
Allocates a block of memory.
Reallocates a block of memory.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
None.
