HM_vectoranalysis()
Creates a vector from two points.
int HM_vectoranalysis(HM_vectorpointer vector, double point1[3], double point2[3]);
HyperMesh hmlib Function
- vector
- A pointer to a vector where the result of point2 - point1 should be stored.
- point1[3]
- A point in space.
- point2[3]
- A point in space.
If successful, the function returns zero; otherwise, nonzero.
None.
