HMRES_openinputfile()
Opens an input file containing results.
FILE * HMRES_openinputfile(char * filename, char * mode);
HyperMesh hmreslib Function
- filename
- The name of the results file to be opened.
- mode
- The type of file to be opened. Use:
This function can take the arguments passed in by you and open standard input as its input stream, if a file name is not specified.
None.
