HMRES_ResFileSizeLimitReached()
Checks to see if the res file has reached the size limit.
short HMRES_ResFileSizeLimitReached(char *outputfilename)
HyperMesh hmreslib Function
- outputfilename
- The name of the res file.
Zero, if the size has not been reached.
One, if the size has been reached.
For use with HMRES_ResFileSizeLimitReached, HMRES_SetOutputFilename, HMRES_UpdateToNewOutputFilename, and HMRES_SetFileSizeLimit.
None.
