delete animation
Deletes the model.
delete animation model <file>=<value1>
delete animation result <file>=<value>
Arguments
- model
 - Delete the model.
- file=<model filename>
 - Select the file path or enter the name of the model to delete.
 - id=<model id>
 - Enter the model's ID.
 - result
 - Delete result files.
- file=<result filename>
 - Select the file path or enter the name of the result file to delete.
 - id=<model ids>
 - Enter the result files IDs in range syntax.
Examples
delete animation model file= "C:/model files/truck.key" id= 1
delete animation model id= 2delete animation result "d:/test/doe1.h3d"
delete animation result id=2-5
