mark measure
Marks measures.
mark measure all
mark measure clear argument
mark measure <dictionaryrange>
mark measure displayed
mark measure <label>
mark measure <labellist>
mark measure <range>
mark measure select
Arguments
all
Mark all measures.
clear
Clear all measures.
all
Clear all measures from mark.
dictionaryrange
Clear measures from mark with names between {[<start>,} <end>\].
displayed
Clear displayed measures from mark.
<range>
Clear by measure ID.
For example, 1-4,9,13?,3*.
"Measure *", Measure2, MyMeasure*
select
Clear selected measures from mark.
dictionaryrange
Mark measures with names between <start> and <end>.
displayed
Mark displayed measures.
<label> <labellist>
Marks measures based on labels or lists (wildcards supported). For example, "Measure *", Measure2, MyMeasure* and "Measure *", Measure2, MyMeasure*.
<range>
Mark measures by ID.
select
Mark measures by selection, interactively selected from the modeling window.
select only works in HyperWorks.
Clear marked measures between a defined start and end range:
mark measure clear dictionaryrange "Dynamic MinMax Result" "Static MinMax Result"
Mark all measures:
mark measure all
Mark displayed measures:
