open parameterizedsession
Open a session file and set parameters.
open parameterizedsession add <session file>
open parameterizedsession append <template file> <name>=<value>
open parameterizedsession overlay <template file> <name>=<value>
open parameterizedsession replace <template file> <name>=<value>
Arguments
add
Use the file browser to open the session file, <session file>, with parameters. This file becomes available for the append and replace arguments.
append
Append pages in a session with the template file, <template file>. Select from the displayed files.
Default values for <name>=<value> if not otherwise defined:
autofitx=on/off
Locks the x axis of the current plot so that it does not change as new plots are overlaid. Default is "on".
autofity=on/off
Locks the y axis of the current plot so that it does not change as new plots are overlaid. Default is "on".
autoplacenotes=on/off
Automatically fits any notes you add to the window. Default is "off".
usereportcolors=on/off
By default, when set to "on", line colors, line styles, symbol colors, and symbol styles are applied based on the report template.
PLOT_FILE_1="<filepath>"
Select a file from the file browser.
overlay
Overlay pages in a session with the template file, <template file>. Select from the displayed files.
instance
This option only affects the report if there is more than one appended report, followed by an overlay. The input is a number which determines which appended report the overlay report is applied to. For example, after appending a report with five pages three times (15 pages), overlay the report over the 3rd instance (pages 11-15) instance=3.
Note: Only the instance and not the page number is accepted.
replace
Replace pages in a session with the template file, <template file>. Select from the displayed files.
autofitx=on/off
autofity=on/off
Examples
Add a parameterized session:
open parameterizedsession add C:\working_directory\report_1.tpl
Append the current session with another parameterized session file:
open parameterizedsession append report
Overlay an existing session with another parameterized session file:
open parameterizedsession overlay bumper_reportparams
Replace a parameterized session with another file:
open parameterizedsession replace new_report_1
