result fileset
Create and manage file sets for derived loadcases.
result fileset create <name>
result fileset <name> addbydirectory
result fileset <name> addbyfile
Argument
- create
- Create a file set.
- <name>
- The file set name.
- <name> addbydirectory
- Add files to a file set using a directory and a search string.
<name> is the file set's name. Options include:
- filedirectory=< directory >
- Define the directory path.
- filesearchstring=<searchstring>
- Search string to search for files inside the directory. Wildcards (*) supported.
- filerecursivesearch=<true/false>
- Select true or false to search in subdirectories.
- load=<true/false>
- Select true or false.
- <name> addbyfile
- Add files to a file set using a file list. <name>
- file=< file_path_list>
- Define the file path list.
- load=<true/false>
Examples
file=d:/test/doe1.h3d
"d:/test/doe 1.h3d"load=falsefiledirectory= "d:/test/run 2"filesearchstring=*.h3dfilerecursivesearch=false
