result tensor plot
HyperView - MultiCorePlots the tensor data type results.
result tensor plot <name>
Argument
- <name>
- The name of the tensor results to plot.
result tensor plot "Stress, Analysis System"
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
HyperView - MultiCoreLoad and unload animations.
HyperView - MultiCoreCancels all currently loading results.
HyperView - MultiCoreCreate and manage iso plots.
HyperView - MultiCoreCreate and manage contour plots.
Set the current simulation.
Makes a subcase current.
HyperView - MultiCoreCreate and manage tensor plots.
HyperView - MultiCoreClears the tensor plot and returns the model to its original state.
Changes the tensor color by direction.
HyperView - MultiCoreCreates a tensor data type.
HyperView - MultiCoreDeletes tensors from the model.
Changes the value display.
HyperView - MultiCoreEdits the tensor data type.
Clears the tensor plot from the graphics window.
Edits the tensor plot legend properties.
Defines the legend's maximum value.
Enables the legend's maximum value.
Defines the legend's minimum value.
Enables the legend's minimum value.
HyperView - MultiCoreLoads the tensor data type.
The multiplier for scaling the result values.
HyperView - MultiCoreRenames the tensor definition.
Displays the current tensor plot in the modeling window.
HyperView - MultiCoreUnloads a tensor data type.
HyperView - MultiCoreUpdates the tensor plot.
HyperView - MultiCoreCreate and manage vector plots.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Perform actions on XY plot files.
Result loading.
