::hwp::GetAxis
Gets an axis handle of a 3D plot client.
::hwp::GetAxis
Tcl Query
This procedure implements minus options.
This procedure returns an axis handle of HyperGraph.
If no page ID is requested, then it operates on the current/active page.
If no window ID is given, then it returns an axis handle of the active window.
Mandatory Arguments
-type "x/y/z"
The type of the axis.
Optional Arguments
-page "page id"
The page where the 3D plot is located.
-window "window id"
The window where the 3D plot is located.
Returns
Returns an axis handle to the belonging type.
set zAxisHandle [::hwp::GetAxis -type z]
