mdlIObject IsSystem
Determines whether an entity is a system or not.
mdlIObject_handle IsSystem
MotionView Tcl Query
This command determines whether an entity is a system or not.
hwi OpenStack
mySessionName GetProjectHandle myProjectName
set activePageNum [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $activePageNum
set activeWinNum [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $activeWinNum
myWindowName GetClientHandle myClientName
myClientName GetModelHandle myModelName
myModelName GetChildHandle hand_1 p_cp
hand_1 IsSystem
myModelName BeginFlatListFastGet System
myModelName GetChildHandleByIdx hand_2 1
hand_2 IsSystem
myModelName EndChildFastGet
hand_2 ReleaseHandle
hand_1 ReleaseHandle
myModelName ReleaseHandle
myClientName ReleaseHandle
myWindowName ReleaseHandle
myPageName ReleaseHandle
myProjectName ReleaseHandle
mySessionName ReleaseHandle
hwi CloseStack
Returns true if the entity is a system, otherwise false. If a system does not exist at the specified index position, the command prompt returns 7.
